d2 clutch problem
dardd2
07-05-2005 16:43:58
I need help! I was dozing tonight with the d2 1st gear not really working it 1/4 throttle maybe and it just stopped moving...when I disengaged the main clutch it made a shuddering sound, now if you pull the main clutch partially and very carefully you can get the tractor to move but it is vibrating something to make it move. also if you pull it to snap in it goes right by and does nothing. I was going to take the clutch cover off and look but I counted 9 deerflies on one arm. any ideas?
hector gemme
07-07-2005 14:13:04
 Re: d2 clutch problem in reply to dardd2, 07-05-2005 16:43:58
HI You have to splitt the d2 for take off the cluch.HECTOR
Bob/Ont
07-06-2005 04:38:41
It's an over center clutch and needs adjustment. The spider needs to be unlocked and tightned untill the lever snaps over center to engage the clutch then locked up again. The spider is on a thread and needs moving closer to the plates.
Later Bob
dardd2
07-06-2005 18:26:00
 Re: d2 clutch problem in reply to Bob/Ont, 07-06-2005 04:38:41
I took off the cover and the fiber teeth are all in the bottom of the clutch compartment,so I will have to replace the clutch, anyone have any thoughts on whether I can get the engine seperated without taking the dozer off?? thanks for the help. Dave Atwater
Bob/Ont
07-07-2005 07:29:51
 Re: d2 clutch problem in reply to dardd2, 07-06-2005 18:26:00
Not too familliar with D2 but the D4 clutch will come out the top. Maybe yours will too. Should uncouple at the back. I think it will handle better if it's engaged.
Later Bob
hector gemme
07-05-2005 17:23:44
HI That should be a pine cam collar is hout .GOOG LUCK and I have some use d2 parts
