Bobcat 453-Drive Problem
RKH
07-07-2005 16:52:25
My Bobcat 453 lacks power to drive the left side in forward & reverse. The right forward/reverse drive works fine & the bucket lift, tilt also work. I raised the machine up with a floor jack to test. Without weight on the left side, the forward/reverse works but turns at a slower/reduced speed in comparison to the right. I changed the hydrostatic fluid & filter on the machine so I know the level is correct. Does anyone have any idea as to the problem & repair.
gatractorman
07-08-2005 13:00:56
 Re: Bobcat 453-Drive Problem in reply to RKH, 07-07-2005 16:52:25
I'm not familiar with the 453 drive system, but it popped in my head to tell you to make sure the lever on the pump is moving as far as it should both ways. The bigger Bobcats have aluminum pump levers and they get worn or the bolt comes out of them and they will act to way yours is.
