Massey 300 tracks / sprockets
Peter B.
07-11-2005 17:30:24
I replaced my tracks and sprockets on my Massey 300 with track chain, pads and sprockets made for several model Case dozers. I purchased all the parts from S.Cohn & Son in Indiana.
The track chain number is CA695-37 (37) is the number of links. You will need 2 of these track chains. The sprocket number is CA 170. You will need to use the orginal Massey sprocket hubs. I cut the teeth of my old sprockets, then cut the hub out of the new Case sprockets and welded them together . You need to cut the teeth off at the largest diameter possible ,under the tooth web, to assure that you get as close as possible to the correct offset between the center of the teeth and the hub mounting surface. I still had to shim out the complete under carriage frame about 3/8 of an inch to align the sprockets with the center of all the rollers. This is not hard to do. The new Case tracks run on the Massey rollers just fine. My machine had 16" pads on it orginally but S.Cohn was out of 16" pads when I order the chains and sprockets ,so after carefull measuring ,I went with 18" pads and they just barely clear. I have about 30 hours on the dozer since this change over and all is well. New chains, pads, and sprockets are going to run you just under $4000.
This machine was just too good not to do something, sprockets were totally shot. If anyone is serious about doing this I could borrow a digital camera and take some photos of the finished job.
Peter B
hector gemme
07-13-2005 01:37:22
 Re: Massey 300 tracks / sprockets in reply to Peter B., 07-11-2005 17:30:24
HI I have 1 good sprocket, 2 idler and more for 300 m.f.and same for 2244 m.f.
Clement Dussault
04-16-2006 06:15:54
 Re: Massey 300 tracks / sprockets in reply to hector gemme, 07-13-2005 01:37:22
need idler 802-274-2010
Peter B
07-12-2005 17:49:01
Marlowe is right. Berco does not have them. When I first contacted Berco about a year ago, they told me they offered them, when I ordered them, Berco called me back and said they have NOT had them for several years even though they are still listed in their parts interchange books.
Peter
Backhoe Joe
07-12-2005 05:31:23
Did you ever try to contact Berco of America? I have a MF 2244 and they offer Weld on sprockets, rollers, track chains, and idlers. They qouted me around $800 for a new track chain which is what most people are trying to get for used ones.
marlowe
07-12-2005 16:00:13
 Re: Massey 300 tracks / sprockets in reply to Backhoe Joe, 07-12-2005 05:31:23
berco has not had 300 tracks or rollers or sprockets for 6 or 7 years and if they still have them for a 2244 you better get them fast
