Case 350 crawler power shuttle
John Bailey
07-11-2005 18:47:23
After crawler is warmed up,will not go forward. Owner had 90wt oil in shuttle. Drained oil,put correct hyd oil in,same. Let cool down,it runs again till heats up. Smells like oil is overheating.Does run in reverse when heats up.Going to check pressures at shuttle per svc manual in forward and reverse with oil warmed up. Oil looks to be much darker coming out than clear going in. I am plumbing new oil filter housing in with spin-on filter before I check pressures. Which is better,rebuilt shuttle or overhaul kit? Thanks for your help.
