Say Marlowe others - Case ?
mud
07-12-2005 07:06:45
Will the 188 in a 480 industrial tractor fit up in a Case 450 loader?
marlowe
07-12-2005 11:57:14
 Re: Say Marlowe others - Case ? in reply to mud, 07-12-2005 07:06:45
you might have to change the front mount and make sure the TC will match to the crankshaft
jcmarleau
07-13-2005 18:27:12
 Re: Say Marlowe others - Case ? in reply to marlowe, 07-12-2005 11:57:14
nice to hear you got the old lady back to work . Yes you can do it without removing the barrel as long as the Gland nut on the end is not stuck in rust Use a good spanner wrench with a long bar sdo you have enough force. some do come out easy but most after many year need a little heat and some need a lot of heat. Last week had to heat a stabilizer gland nut for at least 10 minutes before it broke loose asnd had to keep the heat till we got it halfway. good luck jc.
stressfree
07-15-2005 01:39:55
 Re: Say Marlowe others - Case ? in reply to jcmarleau, 07-13-2005 18:27:12
thanks.will pull this weekend.
stressfree
07-13-2005 01:40:13
jc i hooked up the valve on the 26c.works ok.ran it hard for an hour.its been sitting years.finaly bucket packet blew.hows it to change that packing? can you leave the tube on the machine and pull the ram out?
