It's hotter than normal up here in NY, it's been over 90 degrees here almost every day.I'm dragging trees & pulling stumps with the backhoe. If I run the 575D with the engine side covers on, I get about 3 hrs out of the machine b4 temp gage shows red. If I run it without the engine side covers, I get about 5 hrs out of the machine b4 gage goes red. It never stalls out, but boils over when I shut it off if I let the gage go red. When I did maintenence on the machine after I first bought it, I had to remove the HYD pump & Res in front of the radiator. At that time I powerwashed the fins clear in the RAD, and flushed the entire cooling system from the bottom of the block up. It has fresh 50% orange coolant 50% water... I also replaced thermostat & gasket. Coolant does not leak, does not boil over if I don't let gage go red. I need to get 8-10 hrs straight out of this machine on the weekends. What do I need to look for? B4 I bougth it, I talked to the previous owner as I purchased it from a dealer (It was an end of year trade in) The previous owner said there was a coolant leak, radiator was leaking. He said he put in stuff to seal the leak, but it did not help. Well, I noticed that when I got it, thermostat was not oppening, so watter boiled out of the head and forced it's way past the cap while running (I think this was his "leak") Could the sealer stuff he put in there have damaged the coolong system at all? Could he have filled in some of the RAD cores with that stuff? Would a faulty water pump cause this? There are no leaks at all when it does not boil over, I'm not losing coolant...
