1010 Steering
Craig
10-03-2001 22:12:42
Hi, I've got a 1010 that the right side steering clutch is'nt working. I heard a snap before it stop working. What could it be and how do i inspect it Thanks Craig
Lavoy
10-04-2001 21:18:59
 Re: 1010 Steering in reply to Craig, 10-03-2001 22:12:42
Craig,
There is an adjustable rod that is used to adjust the throwout bearing. It is possible that it broke. Remove the square plate on the top of the track clutch housing and you should be able to see it and watch the operation to see if it is something else.
Lavoy
Craig
10-04-2001 13:40:56
Lee, there is resistance when you pull the right brake it will almost stall the dozer, the left side works good, and with no problems. back to the other side , it acts like you are steping down hard on the brake pedal craig
Lee Bradley
10-05-2001 09:24:04
 Re: Re: 1010 Steering in reply to Craig, 10-04-2001 13:40:56
At least part or all of the linkage is good. Remove the top cover and using a flashlight find the clutch release bearing. It's on the shaft coming out of the differentail and should been within about 1/4" of the pressure plate fingers. Once you have found it; pull the steering level and see if it moves against the fingers and moves them. If it moves but doesn't reach the fingers the adjustment bolt may have come loose and the bearing is out of adjustment. If it is not moving then the linkage may have broke as Lavoy suggested. Because the brake is working, the problem is probably the fulcrum shaft (just under the cover), linkage or the bearing operating arm.
Good Luck,
Lee
Lee Bradley
10-04-2001 10:58:24
More information please. Did the clutch or brake or both stop working? Is there any resistance when you pull the level?
