MF 200B Dozer Issues
Gearhead
07-19-2005 05:41:26
Hi all,
Just got an Italian-made MF 200B - I understand that parts are few and far between. I currently has a stuck Perkins 3 cyl. I loaded up the cylinders with diesel and am letting soak. I'm confidant I can get the engine unstuck. HOWEVER my tracks are bad. Couple broken grousers, 1 broken pin, and the pins overall are badly worn. This dozer will be used for small yard work, so I don"t want to spend a ton of money getting the tracks rebuilt (I'm told it's expensive). What are my options? Are there other tracks which may interchange? Is it possible to do a home fix of the broken pin, not having a press, let alone a track press?
Also, is there an interchange for a starter? Mine is good, but I"d like to make a bar starter and I need a junk starter to weld up and install...
Thanks to anyone who can help!
Backhoe Joe
07-19-2005 09:47:03
 Re: MF 200B Dozer Issues in reply to Gearhead, 07-19-2005 05:41:26
I just went through this with my 2244, try Olympictracks.com for under carriage parts they are an aftermarket dealer for berco tracks.
coonhunter
07-19-2005 08:37:35
I have a original M.F. tech. service manual in a nice 3-ring binder. About 3" thick, all pages like new. seems to cover everything. Lots of schematics. (trans, final drives, electrical etc....) $50.00 buys it. thanks, Jim
o
07-19-2005 07:46:57
where are you at ,i have a set of old used tracks,also some parts,1-812-926-0829,i am in ind.,s.e.
hector gemme
07-19-2005 10:06:03
 Re: MF 200B Dozer Issues in reply to o, 07-19-2005 07:46:57
HI I HAVE A SET CHAINE M.F ,ROLLER,SPROCKET,IDLER AND MORE.HECTOR
