JD 450 temperature
motorhead460
07-22-2005 20:25:27
Hi,I have a JD 450b crawler non turbo with a 202ci engine and the h-l-n-r tranny,it doesn't have the gauges that show green and red,they have been swapped out to the regular type that shows the numbers.Was wondering what an average temp for the engine and tranny would be? Thanks
J Ted
07-24-2005 09:47:14
 Re: JD 450 temperature in reply to motorhead460, 07-22-2005 20:25:27
Have a 2010 crawler with the H-L-R trans. Operators manual says that trans oil is overheated when it reaches 230 F. If oil overheats stop trator and run at fast idle till it cools off.
Tom in Central Pa.
07-24-2005 08:19:51
A Rule of Thumb, on oil temperature, The oil operating temperature is usually 100deg. above the outside air temperature.
Roy Suomi
07-23-2005 04:08:03
Engine temp range should be 175 to 190 depending on thermostat installed. Trans should be no higher than 200 I would think... Haven't been asked that question before. Like you said guages usually have color bands showing heat ranges. If the floorboards feel excessivly hot, adjust the HLR transmission to keep slippage down to a minimum.....
motorhead460
07-23-2005 20:00:15
 Thanks for the reply Roy in reply to Roy Suomi, 07-23-2005 04:08:03
My engine runs about 165,if I really work it hard it will go to about 185.I need to do some work on the wiring for the trans temp gauge,at the moment I have no reading but it seems to be running cool,as you said about feeling the floorboards,it all feels cool.Thanks for the info.
