Case Construction King 580B
Lindsay
07-30-2005 04:04:40
Trouble with shuttle shift. Forward OK but no reverse. Charge pressure 155psi at idle. Removed the shuttle top cover and the discs in front clutch vary greatly in width. Lots of oil escapes from it when reverse is applied. I assume shuttle needs repair. I have been told that before dismantling that end play of shuttle assembly should be measured and set correctly after repair. Is this information correct and if so what is that dimension? Any other suggestions?
Thanks.
