1960 A C HD6 axle
naz
07-31-2005 04:08:24
Hi folks,I have a hd6 which I suspect a broken left axle ( track got loose,leaking fluid around axle)heard a pretty good snap!How hard are they to fix? I am looking for a breakdown of that area.Done a little work around tractors but not dozers,I have all the jack and blocking I need.Any help would be appreciated.Thanks,
Naz
Can I move it!!/naz
08-01-2005 05:20:28
 Re: 1960 A C HD6 axle in reply to naz, 07-31-2005 04:08:24
About 200ft to the barn,it's in a cleared feild so it's fairly level earth?Thanks,
Naz
Bob/Ont
08-01-2005 09:14:27
 Re: 1960 A C HD6 axle in reply to Can I move it!!/naz, 08-01-2005 05:20:28
Move it slowly and carefully Naz, you may need another good sized tractor to help the lame side along.
Later Bob
Thanks Bob/Ont
08-01-2005 12:18:25
 Re: 1960 A C HD6 axle in reply to Bob/Ont, 08-01-2005 09:14:27
I'll do that,still looking for a little info. on the breakdown,my first time getting into one of these!!!Any trouble I might get into?Thanks,
Naz
Bob/Ont
08-01-2005 12:53:15
 Re: 1960 A C HD6 axle in reply to Thanks Bob/Ont, 08-01-2005 12:18:25
Naz, I have seen a few of them but not worked on many. The best thing to do when you get it to where you want to work on it is. Split the track and roll it out flat. Unbolt the track frame and jack the machine up so you can roll the frame forward. If it's like most AC crawlers it has a live shaft. The bull gear should come out the back opening when you unbolt the axle bearing cage and remove the remains of the axle.
Later Bob
naz
08-01-2005 14:27:10
 Re: 1960 A C HD6 axle in reply to Bob/Ont, 08-01-2005 12:53:15
Thanks Bob,hope to get at it soon as I get the axle,have a couple lines out for one.Thanks again,
Naz
Tim B in WV
07-31-2005 16:17:40
Hey,Naz, I've got an exploded view of the axle if you can send email,I'll try to scan it and send it to you. It'll have to be tonight,as I work out of town thru week. Tim
naz
07-31-2005 16:36:19
 Re: 1960 A C HD6 axle in reply to Tim B in WV, 07-31-2005 16:17:40
Sent out to ya Tim ,Thank You.
Naz
hector gemme
07-31-2005 10:56:57
HI You have too splitte the chaine,take off the holder,thake off the 4 bolts on arm track frame,take off oil final drive and cover and take off 4 small screws on bullgear luck the shaft. Good luck and I have some hd6 use parts .HECTOR
naz
07-31-2005 16:32:28
 Re: 1960 A C HD6 axle in reply to hector gemme, 07-31-2005 10:56:57
Hi Hector thanks,still looking for an axle, hard to find in Nova Scotia!!
Naz
hector gemme
07-31-2005 16:49:48
 Re: 1960 A C HD6 axle in reply to naz, 07-31-2005 16:32:28
HI I have a shaft sprocket for hd6. HECTOR SEND ME A E-MAIL
Jason smith
01-10-2006 16:59:44
 Re: 1960 A C HD6 axle in reply to hector gemme, 07-31-2005 16:49:48
I am looking for a hydraulic steering pump for a hd6-E. please e-mail me back if you know were i can find one.
naz/OK
07-31-2005 16:58:58
Thank You...
Naz
