swamp tracks for JD350C
T. Stinnett
08-01-2005 20:45:37
question: I now have swamp tracks on a JD350C and need to replace at least the pads. UC is about 70-80% overall. If I just cut the pads down to size would that work for me until the whole track needs replaced? Are those swamp tracks thinner then a standard 12-14" pad? Thanks for your help. Tom
2x4
08-01-2005 21:34:56
 Re: swamp tracks for JD350C in reply to T. Stinnett, 08-01-2005 20:45:37
probably work. I had a JD 450 track loader & someone had put 16" dozer pads on it. Problem was tracks hit the loader frame anytime you weren"t going straight ahead. So I cut 2" off the inside of the pad. This left it uneven, 6" to pad center from inside, 8" from outside. It hurt nothing; used it for years & sold it that way. Seems like a big waste in your case tho.
T. Stinnett
08-01-2005 21:40:34
 Re: swamp tracks for JD350C in reply to 2x4, 08-01-2005 21:34:56
do you think it would be better to just swap them out and sell the swamp tracks?
2x4
08-01-2005 23:35:34
 Re: swamp tracks for JD350C in reply to T. Stinnett, 08-01-2005 21:40:34
sure. You're going to do all that work & expense to make something that's already made everywhere; & swamp tracks are excedingly rare
T.Stinnett
08-02-2005 18:40:41
 Re: swamp tracks for JD350C in reply to 2x4, 08-01-2005 23:35:34
Thanks for the reply 2x4, I am looking for pads, maybe the whole chain too- haven"t decided. JD says their pads are 18$ a piece so am exploring used and aftermarket.
Pete/ME
08-07-2005 03:16:32
 Re: swamp tracks for JD350C in reply to T.Stinnett, 08-02-2005 18:40:41
Whereabouts are you. I've got the old tracks (chains & pads) from my straight 350 crawler that I intend to scrap out. Pads are aren't bad, just didn't want to take the time to remove them from the old chains. I'd trade (could use a r.o.ps) or sell them.
