Cat D4 jumps out of 1st gear
Doc Larry
08-02-2005 04:20:07
I"m looking at a ca 1950 D4 with 5F-1R tranny that"s in reasonable shape but according the the owner jumps out of 1st gear now and then under no load but holds in gear when pushing. If any of you have had a similar problem, is this a bearing or wear-related problem that will require pulling the engine in order to get to the tranny? Any chance this is just a shift mechanism problem? Thanks in advance,
Larry
Bob/Ont
08-02-2005 06:38:49
 Re: Cat D4 jumps out of 1st gear in reply to Doc Larry, 08-02-2005 04:20:07
Larry, I think there should be an interlock to prevent shifting untill you release the flywheel clutch. Try adjusting it. Look for a linkage from the clutch lever to the trans. Later Bob
Doc Larry
08-03-2005 15:28:00
 Re: Cat D4 jumps out of 1st gear in reply to Bob/Ont, 08-02-2005 06:38:49
Bob,
Thanks, I"ll check it out this weekend. Tracks are in great condition, so I"d like to pick this up if the tranny problem is minor.
Larry
Bob/Ont
08-04-2005 06:37:00
 Re: Cat D4 jumps out of 1st gear in reply to Doc Larry, 08-03-2005 15:28:00
Larry, disconnect the linkage and move it back and forth untill you find where it locks the shifter rails. Then adjust the link untill it locks when the clutch is engaged and unlocks when the clutch is released.
Later Bob
Doc Larry
08-06-2005 09:37:33
 Re: Cat D4 jumps out of 1st gear in reply to Bob/Ont, 08-04-2005 06:37:00
Bob,
Just took a look at the D4 again. The interlock blocks Reverse from going into gear, or from being taken out of gear, unless the clutch is released. The interlock prevents 1st from going into gear, but doesn't prevent 1st from being taken out of gear. The interlock has no effect at all on 2nd - You can put it in or out of 2nd regardless of cluch position.
Does this seem to indicate the problem(s) are most likely in the interlock and shifting mechanism - ??
Thanks, Larry
Bob/Ont
08-06-2005 12:09:55
 Re: Cat D4 jumps out of 1st gear in reply to Doc Larry, 08-06-2005 09:37:33
Larry I think the inter lock might be worn out. It's a shaft with grooves cut into it to lock the rails in place. When the clutch is released the grooves allow the rails to move. Did you take the linkage off and try it?
Later Bob
Doc Larry
08-06-2005 14:36:33
 Re: Cat D4 jumps out of 1st gear in reply to Bob/Ont, 08-06-2005 12:09:55
Bob,
I don"t own it yet and at this point don"t have permission to do any exploratory surgury. Thanks again,
Laryr
Bob/Ont
08-06-2005 15:12:42
 Re: Cat D4 jumps out of 1st gear in reply to Doc Larry, 08-06-2005 14:36:33
Larry, just pull the pin out of the link and move the interlock lever untill it locks all the shifter rails in the gear you put it in with the engine not running. If you can do thay and adjust it to that you will be okay. If you can't adjust it then you need a new interlock shaft. Get me the serial# and I will check out the parts for you. Email me.
Later Bob
Doc Larry
08-05-2005 15:48:35
Bob,
I see now what you're saying - the interlock actually keeps the transmission in 1st gear by blocking the shifter rail from moving until you release the clutch. Sounds like this could easily be the problem, I'll check it out....
Thanks again.
Larry
hector gemme
08-02-2005 10:13:16
HI BOB has rason that should be the interlock.but you can try whent the motor died you shift the transmission after engage the main cluch and try to desengage the transmission and if only the first speed his easy to desangage that should the first gear use. I have some use d4 parts. HECTOR
Doc Larry
08-03-2005 15:30:05
 Re: Cat D4 jumps out of 1st gear in reply to hector gemme, 08-02-2005 10:13:16
Hector,
I understand about disengaging the various gears and comparing, but I don't understand when you say, at the end, if only 1st is easy, "that should the first gear use". Can you or someone clarify?
Thanks for the help,
Larry
hector gemme
08-04-2005 00:40:10
 Re: Cat D4 jumps out of 1st gear in reply to Doc Larry, 08-03-2005 15:30:05
HI You said the transmission desangage in first if you angage the master cluch whit transmission engage you should not able shift all speed and if you can that should be the interlock but if it only the first speed going hout whell you find the trouble.SEND ME A É-MAIL.HECTOR
