d2 pony motor governor?
m.guy ervin
08-02-2005 04:58:57
I have bench tested the governor at 1750 RPM and the throttle return arm works with out the spring attached, but will not work if the spring is hooked up. the spring tensioner adjustment is backed all the way out. Does anybody know the reccommended RPM range for the pony motor?
M.Guy ervin
08-03-2005 13:54:37
 Re: d2 pony motor governor? in reply to m.guy ervin, 08-02-2005 04:58:57
Tom, have you found out any more info. on the pony motor RPM operating range? I was guessing that it sounded like about 1500 or 2000., thats why I checked the governor at 1750.?? Anyway, problem solved. I was guessing that it was O.K., but after taking it aqpart, I found it to be very rusty. I polished all parts and installed a new bearing and it seems to work fine now. Thnx, M.Guy
TomA
08-02-2005 21:36:57
I don't have a book in front of me but I am sure it is over 3000 rpm, maybe 3300.
LDOFORCNO
10-24-2005 22:48:57
 Re: d2 pony motor governor? in reply to TomA, 08-02-2005 21:36:57
My Servicemen's Reference Book shows 10HP @ 3000 RPM. Tom was right on the mark.
bob
hector gemme
08-03-2005 01:56:33
HI I dont know what the rpm but I have a d2 governor.HECTOR
M.Guy Ervin
08-03-2005 13:56:45
 Re: d2 pony motor governor? in reply to hector gemme, 08-03-2005 01:56:33
Thnx Hector, but I got it working. The Magneto that I bought from you works great. Thnx again, M.Guy
