Rwhite - Welcome aboard. I have an IH 150 loader (1969 model) that I bought about two years ago and have been using on my large wooded lot for clearing downed trees/logging, long driveway building, and for lot clearing building prep. The machine has been fabulous, very reliable and does a great job for what I'm doing. I'll try and address your questions below: "1- Is this machine worth $2K in this present condition?" If it's in good shape in every way except the engine, plus it's a powershift (as opposed to a manual clutch/tranmission model), then I would say definitely yes. The only problem is verifying that everything else works (tranny, clutches, final drives etc) which is almost impossible to do without it running. Also, verify that the undercarriage (U/C) is in good condition, which is the most important part of assessing an old crawler's value. Make sure the U/C is in decent/usable shape, hire an expert if you don't know. Otherwise the machine is only really worth basically a little above scrap iron price (they weigh about 21,000 lbs). "2- I figure at least another $1500 to put the motor right. Should I just look for another good motor to swap in, or, re-build this one?" The 282 is a good motor, mine has been great and overall I'm very pleased with it. The only complaint I have with it is that it's a bit hard to start when it's ice cold. Also, the older IH's are known for getting cracked heads if you shock cool them or overheat them badly. So try and verify that the head is not cracked, but even if it is, the 282 was a common motor in IH farm and industrial equipment. Rebuilt, new and used parts are widely available, so I wouldn't worry much about that. "3- On this 282 engine, are the cylinder bores sleeved? If they are...Is it easy (in a home shop) to remove the old sleeves and install the new ones? I have a decent amount of gasoline engine rebuilding experience." Not sure if they're sleeved, my engine manuals are not handy right now. Maybe someone else can chime in and advise. "4- I don't seem to be able to find a lot of information on-line about the model #150. (Is it really the same machine as a TD-9)? How can I figure out how old this machine is?" The 150 loader is based on the TD9B dozer chassis. They were made between from about 1963 and 1974. I don't know what the serial number correspondence is with year model. Go to the redpower sight to learn that info (http://www.redpowermagazine.com/forums//index.php?showforum=9). The 282 turbo diesel engine was used in the gearshift models (producing 71 hp) and the naturally aspirated 282 (producing 75 hp) was used in the powershift model. The weight with 4-1 bucket was right about 21,000 lbs. This machine is very versatile and very powerful. It can do an awful lot of work for you without complaint. Here's my loader earning its keep, it's been a great machine, I recommend the 150!
