HD6 axles breaking
naz
08-10-2005 06:36:32
Hi folks,was talking to previous owner of hd6b and he said these axles are prone to breaking,this machine had a 2inch diam.solid shaft that run through one side of the track arm through the other with plate washers welded on both sides stabilizing the two together.This was taken of by previous owner and now he thinks it should be replaced when I repair the axle.Could anyone tell me if there was trouble with these machines so that this had to be installed.Any thoughts would be appreciated,
Naz
hector gemme
08-11-2005 16:45:51
 Re: HD6 axles breaking in reply to naz, 08-10-2005 06:36:32
HI The hd 6 has two shaft model ,one whit 6 big spline and the other 20 small spline .good luck. HECTOR
Gary Mckenzie
08-10-2005 13:01:59
Is your machine a dozer or loader? We ran a HD6G loader on the farm for a long time, we used the bucket and a 10' blade on it. We broke a lot of things, but never a final drive. Ours had loader pads so it may not have had enough traction to cause problems. Other than the lower end of the Buda 344 or AC 6000 I can't think of any "weak" points. Hope this helps!
naz
08-11-2005 02:59:18
 Re: HD6 axles breaking in reply to Gary Mckenzie, 08-10-2005 13:01:59
Hi Gary ,I have a dozer and believe there is something causing this just don't know what.This axle broke inside of the nut at sprocket.Thanks,
Naz
Bob/Ont
08-11-2005 05:27:02
 Re: HD6 axles breaking in reply to naz, 08-11-2005 02:59:18
Naz, do you mean the shaft is to keep the track frames parralell to the machine? Ask for more pic from the guy that helped you before. Undercarrage pic's. If it's missing parts that can cause problems.
Later Bob
naz
08-11-2005 06:20:49
 Re: HD6 axles breaking in reply to Bob/Ont, 08-11-2005 05:27:02
Hi Bob,yes it was put in for that reason,then cut off by previous owner(he said tracks would not run independent with it in.)I bought this machine from him with axles repaired ,he didn't say anything about trouble with it?I will get some pictures of undercarriage.Thanks,
Naz
hector gemme
08-10-2005 09:33:44
HI These hd6 are not more probleme of the outhers when you see oil leaking you repair before broken.NOW I HAVE SOME HD6 USE PARTS.
