clutch and track Question
BuckB
08-12-2005 05:45:52
I have a long 610 crawler that nobody seems to have heard of. The right side clutch is slipping in with a good load on it, and the fellow that I got it from said that he replaced the clutch before it set up for two years. With very little load it bites good. I s there anyway to adjust this clutch or will it need to be replaces. Also I cannot find the grease zert to tighen the tracks. I can see the tersion spring and several different zerts on the rail but nothing to tighten the tracks. I figure that this machine should have the same consept as other but not all. Please help it will be greatly appreciated. Thanks Buck
JTed
08-13-2005 14:06:09
 Re: clutch and track Question in reply to BuckB, 08-12-2005 05:45:52
Buck, my experience with crawlers is limited but will try to help. I have had two JD. a420 and 2010. 2010 was slipping on right clutch also. I was able to remove seat,batteryetc,and top of steering clutch control housing and tighten each of the 3 adjusting screws (turn counter-clockwise) to put more pressure on clutch facings. Is track adjustment mechanical or hydraulic? Some have "adjusting tubes" or a threaded rod instead of a grease zerk. Hope this may help.
