backhoe bucket
Hawke
08-12-2005 13:41:21
Found a backhoe bucket marked 14806B tried Cat, Ford, case, JD not their number. Any sugg.??? Thank You.
Bob/Ont
08-12-2005 17:53:02
 Re: backhoe bucket in reply to Hawke, 08-12-2005 13:41:21
Hawke,there are lots of welding shops that build buckets for all makes. You need to measure the pin hole dia. width between the Bosses and distance between the pins. Then compare to some known factory built buckets to be sure what machine it will fit. Another thing, take a pic of it sitting flat on the ground, compare that pic to a pic taken of a bucket that measures up the same. If the pin holes don't look like they are in a similar location it might not dig too good on that machine. Linkage Geometry is important to make them dig right.
Later Bob
