Billy NY
08-15-2005 17:42:54
Re: JD 1010 in reply to Lavoy, 08-15-2005 10:30:55
Lavoy, I believe it is without the reverser, I've ran it on occasion, it's a direct drive 4 spd. trans., if I recall correctly, just the transmission lever and a pedal clutch. While not familiar with the JD's all that much, I assume that it's a dry clutch assembly, by the brief description given, it would have to think it would be in the clutch assembly, it does go into gear, and will apparently move at a low idle, which got progressively worse until now. I'd think if the clutch was failing, it would be hard to get into gear, but in case there was a possibility of some other issue causing this, I'd thought I might ask here, and especially appreciate any insight provided. He's got the books on it and it's not too far from the garage so I'm sure we'll get in for a look, but I'm no expert on the JD's though. I just got the upper bell housing off my D-7 to do a clutch replacement, when it rains it pours !
