Late JD 450A Steering Brake
jj05
08-15-2005 10:03:09
Anybody know if the right steering brake bands can be replaced without removing the track, sproket etc.? I.e. through the access holes. I have an oil soaked one from overzelous lube job.
Thanks
Jon
Roy Suomi
08-15-2005 19:24:05
 Re: Late JD 450A Steering Brake in reply to jj05, 08-15-2005 10:03:09
Yes, but it's not a real easy job. Remove tank assembly [ fuel tank , hydraulic tank , battery box ] all in one piece. Remove steering clutch top cover, remove all linkage inside clutch housing, rotate brake band assembly to unhook spring in bottom of housing. Rotate band assembly to remove from drum....Band is a 2 piece deal. Be sure to hook spring in bottom when reassembling, otherwise the brake band won't apply and release right..Use neverseize on all rotating linkages...
jj05
08-16-2005 10:23:31
 Re: Late JD 450A Steering Brake in reply to Roy Suomi, 08-15-2005 19:24:05
Thanks, Looking at the manual it seemed possible.
Jon
