T D 6 steering clutches adjustment
Ray Hudson
08-16-2005 18:18:51
I need imformation on how to adjust steering clutch on a old td6 thanks
hector gemme
08-17-2005 02:24:36
 Re: T D 6 steering clutches adjustment in reply to Ray Hudson , 08-16-2005 18:18:51
HI the adjustement is under the seat you whill see two turn-buckle ,you loose the lock nut and turn the turne- buckle several turns to shorten the linkage then tighten the lock nuts againts the turne-buckle. check to see if the free movement of the cluch lever is between two and four inches.I have some use td6 parts .HECTOR
