Fiat Allis FD7 clutch problem
RhinoJohn
08-17-2005 16:02:36
When my FD7 gets warmed up good, the right clutch is extremely hard to disengage. It seems to be in the hyd control valve under the seat. Any clues?
billy cathey
08-20-2005 08:52:56
 Re: Fiat Allis FD7 clutch problem in reply to RhinoJohn, 08-17-2005 16:02:36
Had the same problem w/ my FL 14. Had to replace the steering hub & seals. Requires removing brake drum assembly. Takes a special puller to remove the hub. I made my puller, it looks a lot more dificult than it actually is once you get into it. It"s probably a good idea to go thru the brake boosters & main control valve assembly while you have it apart.
good luck and hope this helps
