clutch adjustment info
Dirty Eddies Do
08-18-2005 20:56:45
need info on clutch adjustment for a 14a D8 Caterpillar
hector gemme
08-19-2005 01:51:49
 Re: clutch adjustment info in reply to Dirty Eddies Dozer work, 08-18-2005 20:56:45
HI The d8 14a has a oil cluch, take off the top cover and you will see tow nut 3/4 whit plate block 2-2 inchs ,you loose the two nut and push turning the sladind pressure cluch just 1 inch whit bar and hamer after try your hand cluch if it snap but dont forget too look your 3/4 NUT BEFORE START THE MOTOR.HECTOR
