MF 200-B steering clutch
David C.
08-26-2005 15:52:47
Can anyone tell me how to adjust the steering clutch on a Mf 200-B ?
Thanks! David C.
coonhunter
08-31-2005 14:19:39
 Re: MF 200-B steering clutch in reply to David C., 08-26-2005 15:52:47
I have a nice tech. service manual that covers MF 200/200B crawlers. It's in a 3-ring binder, about 2 1/2" thick. Like new. I'll take $50.00 for it. E-mail if interested.
marlowe
08-26-2005 16:42:08
this is not EZ to explain but i'll fax the info to you if you give me a fax no. what state you in might bring it to you if close [sunday bike tripe]
David C.
08-26-2005 17:31:44
 Re: MF 200-B steering clutch in reply to marlowe, 08-26-2005 16:42:08
Thanks Marlowe. Whats going on is the right steering clutch is slipping. As far as making a turn it works fine. I noticed that there is a bolt with a locking nut on the back of steering clutch-brake housing . I assume this may be some sort of adjusting bolt. My fax number is (606)754-8723. Thank again. David C.
backhoejoe
08-29-2005 07:17:17
 Re: MF 200-B steering clutch in reply to David C., 08-26-2005 17:31:44
that bolt with a jam nut is for adjusting your steering brakes, there are two to each side one on the back and one on the bottom. The manual suggests adjusting your steering brakes if you adjusted the clutches.If you have any more questions I can help as much as I can with the 2244crawler manual
marlowe
08-26-2005 18:39:27
the book i have is for a 200 not sure the 200b is the same but will fax you the info in the morn
marlowe
08-28-2005 17:01:13
 Re: MF 200-B steering clutch in reply to marlowe, 08-26-2005 18:39:27
just faxed the info. to you 6:50 cst.sunday
David C.
08-29-2005 12:52:29
 Re: MF 200-B steering clutch in reply to marlowe , 08-28-2005 17:01:13
Thanks for the help Marlowe!
