JD Model 9300 backhoe attachment
Francois
08-28-2005 15:17:29
1) I have made a frame bracket to install the 9300 BH on a 80HP 8030Kubota MUDDER , I have 18GPM PTO gearbox pump but it's not enough...would 25 GPM and 2500PSI pump do the trick? 2)Would anyone have a suggestion to install a pump linked to the PTO with a driveshaft
(but then PTO speed is between 300 and 580 RPM...) 3)also, I'm looking for a 20" (or bigger) bucket for the 9300 model; would other model backhoe; ei CAT or Case be similar and compatible to the 9300? There are a lot of good deals around but I can't tell if it would work save taking combersome measurements...just a beginner asking for advises from the pros!!!
coonhunter
08-30-2005 12:35:56
 Re: JD Model 9300 backhoe attachment in reply to Francois, 08-28-2005 15:17:29
I have a nice 24" J.D. bucket. Located in Ct. E-mail if interested.
Roy Suomi
08-28-2005 20:09:35
Before you start the tractor check the control valve for being open center or closed center control valve . Years ago I ran into a 9300 that had a closed center control valve installed in it.A sure way to tell is to take off the quick couplers, blow compressed air thru one line , if air comes out the other line readily it's an open center valve. If no air comes thru the other line it's a closed center valve..If your tractor has open center hydraulics and you put a closed center valve to it , it will probably blow the hydraulic pump apart....
Heat Houser
08-30-2005 03:01:59
 Re: JD Model 9300 backhoe attachment in reply to Roy Suomi, 08-28-2005 20:09:35
If you look at the main hoses, the closed center setup went directly to the control valve. If the return hose flow goes through the frame (for cooling) then it is open center.
marlowe
08-28-2005 17:08:32
have a 18 in. JD bucket for sale but i put a 36 in case bucket from a 580k on my 9300 and fits right on just had to make longer pins and a few other little thing but NO cuting or welding
mike isdell
05-13-2006 09:05:17
 Re: JD Model 9300 backhoe attachment in reply to marlowe, 08-28-2005 17:08:32
Hello I saw you had an 18" backhoe bucket for a John Deere. I was wondering if you still had it and curious if you still wanted to sell it. Thank you very much i would appreciate a reply.
Mike Isdell
srs/mn
08-28-2005 16:06:56
1. Your pump should work - the manual shows that a 9300 backhoe uses 28gpm at 2250psi whan mounted on a JD350C.
2. Will you have room for a PTO mounted pump after you mount the backhoe?
3. Take the time to find a JD bucket that fits your hoe... others can be made to fit, but it's a lot of work, and getting the pin geometry right is very important.
srs/mn
