JCB 3C mkII - steering problem
AndyH
08-30-2005 11:58:32
I recently acquired my father"s JCB 3C mkII. He purchased this machine new in 1979/80 and operated it until his recent death. Unfortunately his broad knowledge of this machine is now history and I am trying to keep the "old girl" running.
My problem is related to the steering. At high RPM"s it is OK but at low RPM or idle, it is almost impossibel to steer. I have checked the hydraulic screen and it is OK. I have also swapped the steering cylinder with a spare one from another JCB we have for parts, still the same problem.
Does anyone have any suggestions? Does this machine have a separate steering pump?
Your help would be appreciated.
AJK
09-01-2005 17:57:56
 Re: JCB 3C mkII - steering problem in reply to AndyH, 08-30-2005 11:58:32
Yes it has a separate pump for the steering but it uses oil from the main hydraulic system to operate,sounds as if the pump is worn when you have no power at low engine speed,the main relief valve for the steering is in the pump itself,it is located on the back plate of the pump at an angle underneath a domed nut,you need a 13/16AF slim wall socket to remove it to check the valve,the pressure is adjusted by shims,have a look at the valve first,the pump is mounted on the back of the timing cover of the engine underneath the injector pump,its got an oil feed pipe from the chassis which is hollow and doubles as the hydraulic reservoir,if you have to remove the pump you will need the loader raised,make sure its empty and that you secure it so it will not drop on you,the oil level is much higher than the pump so you will need to block the oil flow when you undo the pipes,it is not practical to drain the oil as the system holds an enormous amount.
AJ
AndyH
09-02-2005 05:22:35
 Re: JCB 3C mkII - steering problem in reply to AJK, 09-01-2005 17:57:56
Thanks AJ - Will hopefully get at it this weekend. Will follow up next week with the result.
