T6 Water in main clutch housing
Chuck's Repair
08-31-2005 18:15:43
Are there any drain holes under the main clutch housing?If so where are they located.This crawler has set for about 30 years outside and has water covering the bottom 1/4 of the flywheel.The clutch linkage is also rusted solid.Any help freeing that up whould also be helpfull.Thanks for any help. Chuck
hector gemme
09-01-2005 02:32:16
 Re: T6 Water in main clutch housing in reply to Chuck's Repair, 08-31-2005 18:15:43
HI Yes in my parts book I see some hole in the main frame housing cluch.These hole are for the screw cap equalizer spring shaft and if you take off a screw the water should going out. HECTOR
King of Obsolete
08-31-2005 20:24:33
yes there is, pull one of the 6 bolts that hold the draw bar on. then poke the dirt out and the water will run out. join us at redpower BB
Link
thansk
www.kingofobsolete.ca
