cat d7e problem
Daveminn
09-04-2005 05:20:16
Was using my d7 yesterday and suddenly it started missing on 1 cylinder and would smoke when under load,lacked power when pushing.Worked real good all summer long otherwise, could it be the turbo going bad?can anyone tell me what could be going on?Thanks for any help in advance!
Dave minn
09-04-2005 11:37:34
 Re: cat d7e problem in reply to Daveminn, 09-04-2005 05:20:16
Air cleaner is clean,Doesnt smoke till under load.Smoke is dark and engine only smokes when speeding up engine.Should I check turbo next?How do you check it? This all happened suddenly ,worked great with no smoke when pushing hard till yesterday ,while pushing some topsoil away.Dave A
Bob/Ont
09-04-2005 11:54:31
 Re: cat d7e problem in reply to Dave minn, 09-04-2005 11:37:34
Dave it sounds like you may have lost a turbo, hope it didn't dump it's cookies into a cylinder. With the engine Cold and NOT RUNNING, take the exh stack off, reach in and try to spin the turbine wheel, also check for loose bearings. If it packed up real bad and broke a shaft you would have oil pouring out the stack onto the hood. When the turbo is working right on a good engine it should increase the intake manifold pressure about one Atmosphere, App 15 PSI when the engine is at full load.
Later Bob
hector gemme
09-04-2005 11:03:14
HI IF he smoke black it mabe the air cleaner dirty and if it is the turbo you should not hear operate good luck. HECTOR
Bob/Ont
09-04-2005 07:34:49
What colour is the smoke? Does the engine make any unusual noise? Loosen the fuel lines one at a time untill you find the cyl that is not fireing and come on back with what you find.
Later Bob
