Cat 12 grader serial # location
Steve in SJ
09-04-2005 08:34:25
Where is the serial # located on an older cat 12 grader, It is pony start.
hector gemme
09-04-2005 10:27:18
 Re: Cat 12 grader serial # location in reply to Steve in SJ, 09-04-2005 08:34:25
HI The serie number are where BOB told you and I have manual services and instructions and mabe parts. HECTOR
Bob/Ont
09-04-2005 08:42:03
There should be a plate on the side of the engine block and one on the side of the frame up front. The engine and machine share the same #. If you can't find a plate look for two small rivit holes about 2" apart where the plate was. The frame and the block are stamped with the number under the plate aswell.
Later Bob
Steve in SJ
09-04-2005 09:34:18
 Re: Cat 12 grader serial # location in reply to Bob/Ont, 09-04-2005 08:42:03
