D7E crawler problem(what I found to be the problem
Daveminn
09-05-2005 11:36:40
Checked turbo out and it is good,took valve cover off the back head to view lifters and found 2 bent push rods,lifters kicked out of the hole above cammshaft,1 push rod down the hole against the camshaft.Dont know if it is bent or broke yet.Question:can this be repaired without taking off the head via a magnet fishing out the rod and fishing the lifters back into place?Has anyone got any thoughts on how to save me a lot of work and expense?Can you give me an idea or two as to how to proceed and what I can expect as to the cost to fix?Just bought this machine from a used cat dealer,have put on about 25 hrs and this happened.Seen happier days as money is getting a little slim.Thanks to all who respond,I appreciate the advice!Dave A
hector gemme
09-05-2005 14:07:50
 Re: D7E crawler problem(what I found to be the pro in reply to Daveminn, 09-05-2005 11:36:40
HI You can try whit magnet if you can not,IF IT is in back ead push rod probleme their are side plate being the fuel pump but big probleme to do mabe you have to take off the fuel pump. GOOD LUCK HECTOR
