JD450D final drive
Rudy in TX
09-05-2005 19:19:39
Hoping to get some adviceon my 450D final drive. I took it apart and have discovered that the input shaft gear has some teeth broken. Probably one tooth broke and damaged the others. The bull gear hasn't got any teeth broken off but they are a little rough. Also there is some side to side play in the bull gear. Does the outer spacer and the cone shaped spacer take this side play out? Doesn't seem to have too much wear on the splines on the axle shaft, but was wondering if this little side to side play is too much and if the little damage on the teeth of the bull gear will hurt. Any help will be appreciated. Thanks.
Roy Suomi
09-06-2005 22:11:46
 Re: JD450D final drive in reply to Rudy in TX, 09-05-2005 19:19:39
Any roughness of the bull gear is too much.Just think about the ratio- How many times does that upper shaft go around compared to the bull gear??I'm inclined to think roughness of the bull gear will fill the final drive housing with metalic particles , thus shortening final life. I have seen some side to side slop on the lower shaft.I have seen the bull gear moving far enough to rub the inside of housing. This is way too much....
