Cletrac BDH
JJensen
09-06-2005 19:56:21
I just purchased a running Celtrac crawler. It is a 6 cylinder diesel but I am not sure what year or type. It appears to have about 6 forward gears. I was told it is a "BDH": "B" the size of tractor, "D" diesel engine and "H" for hillside or logging. It has a spool in the rear and fixed blade. The serial number plates on the engine have been cleaned with sometype of cleaner that removed all paint. There are 2 plates on the engine right side. It runs about 15# oil pressure hot. Can anyone tell me anything about what I may have and where to obtain parts for the engine and tracks/rollers.
DGH
09-08-2005 11:13:54
 Re: Cletrac BDH in reply to JJensen, 09-06-2005 19:56:21
The engine should be a Hercules DJXC, 15 psi hot is good. Parts are hard to find. White took over oliver in the 60"s and stopped making crawlers in 65, so there are not many parts around now. Zimmerman Oliver Cletrac is the best source, you will find his contact info and other sources on the Cletrac.org site.
Pete in Cal
09-06-2005 22:27:09
If you don't get answers here try cletrac dot org
