Sellick Teleporter
Tim NGA
09-08-2005 18:51:42
I have a Sellick 249TS teleporter and I need the Gear select lever [6.69"] for the hi low range. The powertrain is a Ford. Any help in parts location would be deeply appreciated
Roy Suomi
09-09-2005 21:22:41
 Re: Sellick Teleporter in reply to Tim NGA, 09-08-2005 18:51:42
Is this the transmission mounted shifter? If so go to New Holland / Ford Dealer with chassis numbers. These numbers should be stamped onto the clutch housing on the flat area above the starter.Take all the numbers to a Ford Dealer, they should be able to tell what you have to get the correct parts..
