fuel tank for 555 ford backhoe
Jack in Georgia
09-09-2005 17:41:04
Can anyone tell me where I might order a new fuel tank for a 555 1985 ford backhoe thanks
Chuck430c
09-10-2005 07:19:21
 Re: fuel tank for 555 ford backhoe in reply to Jack in Georgia, 09-09-2005 17:41:04
I have never used the products but I hear the tank sealers work really well as long as the holes are not too big. Sounds like your gas tank has rusted pin holes in it after you repaired a larger hole?
The sealers will not only stop the leaks but some prevent rust from forming in the future. The repaired tank should last as long as you need it.
Hope this helps.
Roy Suomi
09-09-2005 20:36:09
New Holland can't get one ? I don't know of any aftermarket ones available..Whats wrong with yours ? Can it be welded ?
Jack in Georgia
09-10-2005 03:45:41
 Re: fuel tank for 555 ford backhoe in reply to Roy Suomi, 09-09-2005 20:36:09
Roy I guess ,I will have to find a new holland dealer. The closes one is about 60 miles.I removed the tank and welded the hole but,when I put a couple of pounds of air pressure on the tank ,it will blow out in another place.I guess the old tank has about had it . thanks
