450C 4/1 problem
mk./c
09-17-2005 11:43:13
1982 450C, 4/1 worked perfectly, loaded on to trailer, chained 4/1 in the open position back towards the cab to keep it from creeping closed, (can get more tounge weight this way)(and have done it in the past) and unloaded now 4/1 has to work VERY hard to open and close. Pump strugles to push fluid. All other hyd's work fine/normal. Any body else ever had this problem? Thanks in advance for any help. I'm stranded on a job without the 4/1...
Roy Suomi
09-17-2005 19:25:36
 Re: 450C 4/1 problem in reply to mk./c, 09-17-2005 11:43:13
Either a line got pinched or a cylinder got jammed and possibly causing internal damage. I've never seen anyone haul a crawler with bucket open.Try disconnecting one 4 n 1 cylinder at a time then try hydraulics. You might be able to eliminate a cylinder problem this way.Those lines that run down the boom have a nasty bend by the bucket linkage. I've seen these lines loosen and creep down and get crunched . Good luck..
