Case 350 Power Shuttle Leak
JShip
09-26-2005 07:47:19
The power shuttle on my Case 350 trackloader leaks fluid after it has been ran for an hour or two. It takes about a pint of fluid to fill it back up after an hour or so of use. The fluid appears to be coming through the front seal on the power shuttle into the torque converter. My plan is to remove the power shuttle and replace the front seal. Are there any other areas on the power shuttle that are prone to leak? Once I have the power shuttle out, is there anything else I should replace or look at? Has anyone experienced a similar problem?
