Case 850B parts
jdozment
09-26-2005 19:31:35
Does anyone have a surplus track idler complete with shaft, bearings, seals, etc. I also need a track adjuster front yoke assembly. I found that the left hand idler shaft broke and this allowed the idler to shift backwards into the adjuster front yoke. It has worn into the yoke almost to the point where the grease fitting is located. Case 850B. If parts are used, I would like to find parts that are in pretty good shape. Only want to do this job once.
David in SC
09-30-2005 17:46:59
 Re: Case 850B parts in reply to jdozment, 09-26-2005 19:31:35
Hi JD,
I was looking at ebay tonight and saw some Case 850 idlers and rollers. Item 7550709191.
Good luck.
David in SC
jdozment
09-30-2005 20:08:01
 Re: Case 850B parts in reply to David in SC, 09-30-2005 17:46:59
Thanks for the info, but I decided to go ahead and purchase a new one. It was delivered today.
M R TRACK SERVICE
09-28-2005 20:52:06
I might be able to help you with some of the parts for that idler. Call or email me. 800-564-0383. I am in wisconsin. Thanks virgil
