Adding remote hydraulic to a open center system
chuckinnc
09-27-2005 08:02:34
I have a oliver dozer with a six way blade, I
need to add remotes for backhoe or other impliments. My 4500 ford TBL has a short jumper cable that has to be plugged in the remote connectors when
the backhoe is removed, seems the line runs from the loader valve to the hoe & back to the tank. Could i install a setup on the dozer like this?
Install remotes in the main valve exhaust? The
main valve does not have power beyond port.
Joe(TX)
09-27-2005 09:36:14
 Re: Adding remote hydraulic to a open center syste in reply to chuckinnc, 09-27-2005 08:02:34
Adding a power beyond valve plumbed before the inlet of the existing valve would work.
Another option is to add a power beyond to the existing valve, If possible, and putting another valve downstream. The existing valve would have a large plug on the outlet side, and you would need to know the manufacturer. Some valves will work in series without the power beyond, but most will have problems.
Still another option is to put a diverter valve in front of the existing valve and shift between the two valves.
