Worn drive-plate on flywheel
jdemaris
09-27-2005 18:15:00
All the Deere crawlers with that particular hydraulic reverser rattle at low engine speeds when NOT actually doing any work (in forward or reverse). The noise is usually coming from the driveplate on the engine flywheel. It has a spring loaded dampener that is supposed to supress noise and dampen engine pulses, but it gets worn and sloppy overtime. Deere later changed the dampened driveplate to a set of large springs and anchors in the 350s (called the torsional isolator) - but it was an awful setup and was prone to flying apart and locking the engine up. So, again Deere changed the dampener during the 350D series, and used a large rubber driveplate that seems to be their best effort. 1010s and early 350s that use the spring-loaded driveplate will usually rattle a LOT but rarely completly fail. The later 350s up to the "D" series with the Torsional Isolator DO fail, often.
