stuck motor D4
Brad W
09-29-2005 10:24:43
Does anyone have an idea for freeing up motor on D4 it has been sitting for 10 yrs
old
09-30-2005 18:28:48
 Re: stuck motor D4 in reply to Brad W, 09-29-2005 10:24:43
What I do and so far has worked every time is pull the injectors and fill the cylinders with a 50/50 mix of tranny fluid and turpentine. Make sure its the old type turpentine not paint thinner. I just did that to an Oliver engine yesterday and its running today.
King of Obsolete
09-29-2005 12:11:31
hello, what most of the guys are doing is using carb cleaner and pouring it down where the water had entered. carb cleaner is heavier then water so it will eat it's way down to the rust. then let it sit. next some of the guys are using the BAR STARTER that i have made up to break the engine loose. check out my website and see the BAR STARTER and cats that i have gotten running after 3 years under water.
www.kingofobsolete.ca
thansk
joe in ny
10-03-2005 05:12:37
 Re: stuck motor D4 in reply to King of Obsolete, 09-29-2005 12:11:31
When you finally free up one of these beasts that's been wet, do you just get it running, or do you do a tear down, hone & ring? Have a Pontiac that was wet. Got it free, but haven't talked myself into a tear down. Too bad you weren't closer. Thansk, Joe in ny
hector gemme
09-29-2005 11:41:11
HI You have to take off the 4 injector in fill fuel mix with wd40 but some time he maybe freeze on crankshaft and you been work for nothing or you can shift the transmission hi speed and shift arm cluch and a othor guy pull with tractor slowlay and I have some d4 use parts.HECTOR
