AC 655 Allis Henry Mark V backhoe questions
Herb W
09-30-2005 08:15:41
I'm looking at a 655 crawler loader. Have read most everything I can find here about the HD4 & 650 series crawlers. The undercarriage on this machine is near worn out, but there is a parts machine available on which the u/c shows less wear...probably could be made to last for quite a while since it's for occasional use on a farm.
It was a cool morning when I went to look at the machine, (only a few degrees above freezing) and it wouldn't start without starting fluid. Is this normal for the 2200 series engine? (clock shows 3500 hrs).
Machine has 3 spd trans. and reverser. How durable/reliable are the reverser & trans in these? Do they give any early warning signs? Are the hydraulic systems made up of fairly standard components?
A mark V hoe comes with the machine. The current owner hasn't used it and it's been laying in the weeds for a few years. Looks like it would be a bit of a project to get it working. Are these considered to be a good unit? (agian, it's for use on a farm - not commercial use) Any parts that may be hard to get or fabricate?
Herb W
GLENN PYZAK
09-30-2005 13:26:37
 Re: AC 655 Allis Henry Mark V backhoe questions in reply to Herb W, 09-30-2005 08:15:41
first off 3500hrs and the undercariage is worn out this doent sound right. Parts are getting harder to find for hd-4 and 650 serries and exspensive when you do find them. As far as the mark v backhoe I dont think anything is available from the dealer.I have a Mark V backhoe and i just go to a local hydralic shop for parts.
TIM HIBEN
10-04-2005 11:06:20
 Re: AC 655 Allis Henry Mark V backhoe questions in reply to GLENN PYZAK, 09-30-2005 13:26:37
HI , LOOKING FOR TRACK CHAINS AND A SPROCKET FOR A 655 ALLIS W/LOADER....THANKS TIM 715-643-7800
