977L Cat
alvinnms
09-30-2005 11:04:41
Does anyone know what a new t/converter would cost, for a 977L Cat. The bottom keeps over filling with oil. Have tried everything. Thanks AW
Bob/Ont
09-30-2005 18:46:09
 Re: 977L Cat in reply to alvinnms, 09-30-2005 11:04:41
Alvin before you go $pending all your Yankee Dollars check a couple of things first. Take off the trans pump, mounted in front and opposite the hyd pump. If it is loose the orings could blow and flood the torque. And also check the TC inlet valve mounted on the back of the housing with a hose off of it to the trans. The inlet relief valve is to protect the torque from blowing up when the oil is cold. It will dump into the housing aswell. If it is stuck open it will flood the housing. Then if they are all okay pull the Torque out and drop it out of the housing and take it apart. You might be able to repair it yourself.
Later Bob
