JD 210 C Backhoe loader
Jim Horrocks
10-01-2005 09:41:23
Would any of you know how difficult it is to install a clutch in a JD 210c Backhoe Loader? Also what would the cost run if I could do the work myself. Thanks,
Jim in Oregon
Roy Suomi
10-01-2005 21:37:50
 Re: JD 210 C Backhoe loader in reply to Jim Horrocks, 10-01-2005 09:41:23
Check oil level first. Then change reverser filter and cut the old one apart to look for excessive brass or metallic particles indicating a failure of some sort.Top off oil level after filter change with good quality hydraulic/transmission oil
Jonathan in MA
10-02-2005 13:18:15
 Re: JD 210 C Backhoe loader in reply to Roy Suomi, 10-01-2005 21:37:50
..and just a note...there is no actual filter element on those reversers. There is a suction screen in the small sump and thats it for filtration...
Jonathan in MA
10-01-2005 15:24:55
It would be quite difficult as they have a torque converter and no clutch.
