JD 420C #61dozer blade question
Mike
10-12-2001 19:00:41
Hi,
I am in the process of rebuilding the #61 dozer blade assy for my 420c and am looking for some info. I need to fabricate the brackets which are mounted on either side of the blade and allow the blade to be adjusted at various angles. From what the parts manual shows it is a piece of 3/4 inch inside diameter tubing with 2 pieces of 5/8 inch flat stock welded to it. I need to know the spacing of the holes along the flat stock from the centerline of where the tubing is. It looks like there 2 holes to allow for adjustment. Thanks in advance.
Mike
TonyK
10-17-2001 15:50:15
 Re: JD 420C #61dozer blade question in reply to Mike, 10-12-2001 19:00:41
Hi Mike.
There are 3 holes on each bracket that are spaced 3 3/4" apart.
TonyK.
Mike
10-17-2001 18:39:18
 Re: Re: JD 420C #61dozer blade question in reply to TonyK, 10-17-2001 15:50:15
TonyK,
Thanks for the info! I fabricated the new links tonight and they work great.
Mike
