350 jd backhoe
mark ace
10-03-2005 19:12:42
i have 1967 jd 350 diesel crawler with backhoe mounts just wondering what model hoe fits this machine and how well it will handle it, or is crawler to wimpy? thanks
DGH
10-04-2005 08:12:54
 Re: 350 jd backhoe in reply to mark ace, 10-03-2005 19:12:42
The JD 9300 and 9550 hoes will fit, the 9550 is a little smaller than the 9300. Both are on the large side for the 350. With the hoe on it is very rear heavy mading use of any front mounted equipment difficult.
JAJ
10-05-2005 13:03:19
 Re: 350 jd backhoe in reply to DGH, 10-04-2005 08:12:54
I have a 350-B with the model 9300 hoe and it works great. Very rear end heavy which requires any up hill grade climbing to be done in reverse. Mine has the factory weights on the sprockets and under the draw bar which are designed for setting septic tanks and front loader work. I removed the draw bar weights but that did not help much. When the machine in moving forward, on flat ground, there is only about 30% of the track touching the ground. That is alot of weight being carried by only the rear axles so you'll want to keep travel distances to a minimum. Also, the cylinder that swings the boom is a rotary type cylinder and I have heard bad/expensive stories about the repair of this type cylinder.
