350B Whats the bad news?
Uncle
10-04-2005 14:11:41
Whats the bad news?
I checked the presure at the control valve and I have 150# forward and reverse but the machine will not pull out of its tracks.
Do I need to overhaul the reverser?
If so, what do I need to watch for when pulling engine and reverser?
Brian
Robert in W. Mi.
10-05-2005 14:37:33
 Re: 350B Whats the bad news? in reply to Uncle, 10-04-2005 14:11:41
That "bad" news is, you never even told us what brand it is.... Case?? Deere??? or ??
Robert
Roy Suomi
10-04-2005 19:50:13
Oh , the bad news is it's a lot of freaking work..
Uncle
10-04-2005 19:48:03
Also, there is 150# with the trans in neutral and the control valve in neutral; is this right?
I started pulling the engine when it dawned on me that the presures were the same in all three positions. I am just hoping that I overlooked something and not have to pull the engine/reverser.
Brian
Roy Suomi
10-04-2005 19:46:18
Check the ring gear under small cover directly on top of center section, under fuel tank. If ring gear is turning when reverser and transmission are engaged, the steering clutches are slipping. If you can't find this cover you can remove the back cover of the center section. Drain the oil from transmission and remove 4 bolts from back cover and tap to release back cover . you will see the ring gear clearly there.If the ring gear isn't turning, the reverser is slipping. To remove the reverser, Pull nose , bellypan , drain hydraulic tank[ remember to loosen hyd. tank cap to release pressure.] Remove engine with radiator and pump as an assembly [ hoses to reverser, wiring , throttle cable , air intake , fuel lines , tach cable , hyd. lines at pump , ].. Dozer??? remove dashboard and wiring with surrounding enclosure. Loader??? remove reverser thru the front using a " C " shaped fixture made of angle iron with an eyelet at the top , right of " C " and a hook at the right lower of the " C ". There are 4 fasteners at the trans to reverser joint. Be sure to check the splines at the transmission to reverser coupling for extreme wear of splines.
Uncle
10-04-2005 19:55:48
 Re: 350B Whats the bad news? in reply to Roy Suomi, 10-04-2005 19:46:18
Great help. Thanks
Brian
