International forklift - need help!
mike_r
10-06-2005 19:34:09
I just replaced the fuel filters(2) on my International three cylinder diesel and I am unable to prime the system. This unit isn't equipped with a primer trigger and I would appreciate advice as how I should prime/ bleed the system. I've tried running the motor on Ether/ WD-40, but still unable to get system primed. Any advice, well almost any, is greatly appreciated. Thanks, Mike m_rohkohl@hotmail.com
Uncle
10-06-2005 19:52:32
 Re: International forklift - need help! in reply to mike_r, 10-06-2005 19:34:09
I made a presure cap back when I worked on busses. Take an old fuel cap and drill it for a tire valve stem.
Put 5-10 psi and crack the lines, fuel will push out all the air.
mike_r
10-06-2005 20:17:49
 Re: International forklift - need help! in reply to Uncle, 10-06-2005 19:52:32
Thank you, will give that a try tomorrow morning. Thanks again!
