TD 15
ottis
10-11-2005 06:32:03
my td was not steering to the left so i drove it to the barn for some service the right side was working fine so i found out that the left side was stuck rusted up been holding water for 10 years so i greased every thing and adjusted the steering leavers and brakes now the right side wount steer i have been runnig the dozer for two months with just the right steer can any one help
seann
10-11-2005 07:34:13
 Re: TD 15 in reply to ottis, 10-11-2005 06:32:03
Sometimes rusted/seized clutch packs can be freed up by partially filling the clutch compartment(s) with diesel fuel. Then tie back the clutch lever(s) so that they are constantly in the disengaged position and work the machine extensively. After awhile the clutch(s) might unstick themselves. Also make sure the brakes are adjusted properly, have sufficient pad material on them, and are not soaked/contaminated with grease or oil. Otherwise you'll probably have to remove the clutch pack(s), break them apart, clean them up and reassemble/repair as necessary.
As far as the right side, if you go up a steep hill and pull the right lever, the machine should start veering to the right even without brake - if it does this means the clutch is releasing and the brake is the likely problem (make sure your clutch lever is adjusted properly so that it is really disengaging the clutch though). If this doesn't help you can go to the redpower site to learn more, see link below. Good luck.
ottis
10-11-2005 10:11:36
 Re: TD 15 in reply to seann, 10-11-2005 07:34:13
what affect does the control vale have on the steering how does it work
seann
10-11-2005 12:36:40
 Re: TD 15 in reply to ottis, 10-11-2005 10:11:36
What control valve are you referring to? I'm assuming you have an old TD15 with dry clutches and mechanical hand levers. Does it have some sort of hydraulic power assist system? If so I'm not familiar with them (I have a TD9B), but I'm sure someone at the redpower site will be able to help.
ottis
10-11-2005 19:01:41
 Re: TD 15 in reply to seann, 10-11-2005 12:36:40
my trans is a dry clutch and it has a hyd. valve on top by the six speed shifter that is conected to the steer leavers that has a two stage pump on the right side of the engine just for this system i think this is a model td15-151
Fred Higgins
12-11-2005 16:04:39
 Re: TD 15 in reply to ottis, 10-11-2005 19:01:41
i have a couple td15's i feel you need to go to manual and do a major adjustment including planetry's and brakes on foot pedal's also hand brakes when right you can steer with one finger if planetary's are not kicking tractor out when you pull the lever first notch it will not steer try that adj first if you need more info 606 528 1458
Simon Williams
06-25-2007 22:33:31
 Re: TD 15 info in reply to Fred Higgins, 12-11-2005 16:04:39
i Need all informational on TD15 dozer can u help me Please?
