Help with engine ID IH175B
yellowrosefarm
10-11-2005 09:41:09
I just bought an IH 175B. At least that is what the serial # on the seat base would indicate. Of course the cab has a 175C decal and the hood has "Dresser" on it. Is the model # of the engine cast into the block somewhere? I found the serial# on the left side but no model so far. From what I have been told, the choices are DT360 (unlikely), DT407 (probably) or DT466 (only if seat serial# doesn"t go with this machine). It does run but the PO said it was losing the engine oil probably into the trans. Knowing what I actually have will be a big help in getting it into useable condition.
Heat Houser
10-13-2005 13:49:54
 Re: Help with engine ID IH175B in reply to yellowrosefarm, 10-11-2005 09:41:09
If you found the engine serial number, the first numbers are the displacement in cubic inches. So, if the first numbers are 360, then you have a DT360 etc.
yellowrosefarm
10-13-2005 17:22:04
 Re: Help with engine ID IH175B in reply to Heat Houser, 10-13-2005 13:49:54
The serial number starts with MGO7 so is that safe to assume it"s a 407?
