JD 440 crawler track tensioners inop
fallon3340
10-14-2005 05:02:28
I recently picked up a JD bulldozer and both track adjusters seem to be inop. The model number on the plate says 440 CD. These adjusters are hydraulic (grease gun) operated. Does anyone know where I could find the manual versions for this machine? Has anyone actually rebuilt the hydraulic adjusters? Any info would help. Thanks
Lavoy
10-14-2005 08:40:48
 Re: JD 440 crawler track tensioners inop in reply to fallon3340, 10-14-2005 05:02:28
Nothing to rebuilding them if you can get them apart. Hone the cylinder end, put a new cup on the rod end and install a new seal.
Lavoy
fallon3340
10-17-2005 04:19:42
 Re: JD 440 crawler track tensioners inop in reply to Lavoy, 10-14-2005 08:40:48
Thanks for the info. One other question, when I pumped grease into the left adjuster, it started coming out a hole directly underneath the actuator almost directly under where the grease fitting is. Is there some sort of pressure relief port there or am I looking at a damaged actuator.
